Download Trimble Connect Add-on
The Trimble Connect add-on allows you to open models directly from Trimble Connect and to upload new revisions to models in Trimble Connect. This add-on supports the following scenarios:
  1. Get model from Trimble Connect and upload a new model file to Trimble Connect
  2. Import a model from a local file and upload a new model file to Trimble Connect
  3. Get model from Trimble Connect and save it as a local file
Trimble Connect add-on for Simplebim 11.0
Version 11.0 SR1 / Requires Simplebim 11.0 SR1 or newer
Release Notes
Version 11.0 SR1 – 27.8.2025
  • Bug fixed in reading projects if the max allowed storage size for a project exceeded the number that can be stored in a 32 bit integer.
Version 11.0
  • Initial version with capabilities to download and upload models from Trimble Connect
Instructions
Getting models from Trimble Connect
When you install the Trimble Connect add-on a new ‘Trimble Connect’ item will appear in the Open -menu of the Simplebim start-up screen. Clicking on this item will open the Trimble Connect login dialog and subsequently a dialog for selecting the region, project and file. Once you select the file and import the model, Simplebim will work just like if you had imported a local file.
Pushing models to Trimble Connect
When you install the Trimble Connect add-on a new ‘Trimble Connect’ item will appear in ribbon menu next to the IFC Export -button. If you have multiple connectors installed, then you can find the Trimble Connect functionality under the generic Upload -button. Either way, clicking on the Trimble Connect -item will open the Trimble Connect login dialog and subsequently a dialog for selecting the region, project and folder. Finally you give the name for the new file and upload the model as the new file into Trimble Connect.
