Finding Help for Using Templates
Templates include a lot of different kind of rules you can apply to the models. Each rule have a dedicated section in the Template files. Each section have a subtitle, which is also a link to the documentation. The easiest way to get help for a specific rule is simply to click on the link in subtitle.
You don’t have to master all the rules in order to start automating you BIM data wrangling with Templates. You can simply start by creating a new Template, then finding the right rule to apply, clicking on the subtitle to learn how to use the rule, and then applying it.
Note that the rule specific links and documentation are available from Simplebim 10 SR1 onwards. The older versions of the Templates have only higher level documentation links.
