Import Configuration in Template
IFC Import Settings –section
With IFC import settings you can optimize the IFC import. When you exclude information from the import this will speed up the import but the excluded information will not be available to you when you validate, copy-edit and export the model.
FieldTypeValueDescription
Import 2D AnnotationsYes/NoYes/No2D annotations are symbolic 2D representations of objects.
Import 3D FacesYes/NoYes/NoFaces are needed by tools that modify the 3D geometry. They have no effect on how the IFC is exported.
IFC Import Configuration –section
In this section you can configure the IFC import on a lower level. The items in ‘IFC Import Settings’ are shortcuts for configurations that could also be done in this section, but not all possible configurations have these shortcuts.
ActionChoiceSetAdds the key and overrides any existing value of the given key.
RemoveRemoves the key and any value of  the key.
Append ValueAppends the value to the existing value of the given key.
Configuration KeyTextThe configuration key.For supported configuration keys please consult the technical documentation of the Simplebim IFC import module.
Configuration ValueTextThe configuration value.For supported values for each configuration key please consult the technical documentation of the Simplebim IFC import module.
