Move and Rotate Project
In this section you can move and rotate the project object, typically for preparing a model for use as part of a combined model.
X, Y and Z must be in the length unit measure (mm, m, inch, feet…) of the model.
X | Number | X value | X value of the offset |
Y | Number | Y value | Y value of the offset |
Z | Number | Z value | Z value of the offset |
Rotation (deg) | Number | Angle | Value between 0 and 360 |
Relative/Absolute | Choice | ||
Relative | Adds the X, Y and Z values given here to the current X, Y and Z values of the project, and rotates relative to the current rotation. | ||
Absolute | Sets the X, Y and Z values of the project to the X, Y and Z values given here and sets the rotation to the rotation value given here. |
