Release Notes for Simplebim 11
Simplebim 11.0 (14.5.2025)
New Features
  • Dataflows for easier automated BIM data wrangling. The tools and Excel templates from older Simplebim versions can be used as steps in the new dataflows.
  • New simplified start-up window
  • New Trimmer Mode. Previously Simplebim had a dedicated trimmer workspace for deciding which objects and properties are included. Now there is a universal Trimmer Mode and include/exclude decisions can be made in any workspace.
  • New Home workspace (previously Trimmer workspace). In the Home workspace it is now possible to show only included objects in the 3D window (Trimmer Mode = Off) and in this case the 3D buckets used for trimming don’t waste screen real-estate.
  • New tools for
    • Adding properties
    • Copying property values
    • Adding and modifying groups
    • Including/excluding objects and properties
    • Setting and resetting the appearance of objects
    • Moving objects to container
    • Proximity
Enhancements
  • Streamlined ribbon menu
  • IFC import options for showing the IFC GUID, the IFC line number and using the original IFC names for properties in the user interface
  • User interface reloads reduced when running automation. This gives a better user experience.
  • Improved query user interface and logic.
  • The Splitter tool can now handle also 2D surfaces (previously only 3D solids), which is often needed in infrastructure models.
  • Open and Import of models is unified into one functionality
  • Most recently used files list now included also most recently used folders and most recently exported files.
  • 3D modelling is moved from the Location Editor workspace to the main ribbon and is accessible from all workspaces.
  • IFC export supports exporting a subset of included objects, for example all included walls.
  • IFC Merge: Improved support for IFC4.3 facility and facility part objects
  • News moved to application footer
Bug Fixes
  • Bug importing IfcVibrationIsolator objects fixed
