Template Metadata
When you install a template the information in this section is used for displaying and organizing templates in the user interface. For templates that are not installed this section can be left empty.
Name | Text | The name of the template | The name of the template shown in the user interface. The name of the template file is not shown. |
Description | Text | The description of the template | The description of the template shown in the user interface |
Author | Text | The author of the template | The author (person and/or organization) of the template |
Key | Text | The unique key of the template. | If multiple templates have the same key Simplebim will only load the latest version of the template. (see Version) |
Group | Text | The group to which the template belongs. | This can be for example an organization, application or project. Templates can be grouped in the user interface based on this information. |
Version | Whole Number | The version of the template. | Incrementing the version after modifying the template ensures that you are always using the latest version of your template. |
Startup | Yes/No | Yes/No | Should be template be shown in the startup screen of Simplebim? |
Read Only | Yes/No | Yes/No | Should the user be able to edit and delete the template? If a template is read only it can still be copied and the copy can be edited. |
Link | URI | URI | A link to the documentation of the template |
A picture inserted anywhere on the Settings worksheet will be used as the icon of the template in the Simplebim user interface. The recommended size for the picture is 64×64 pixels.
