Automate Bimsheet
You can use Bimsheet also in automation (templates and scripts) with two tools.
  1. Bimsheet: Export
  2. Bimsheet: Enrich
Note: you could also run these tools from the Simplebim user interface, but the more visual way is to use the Bimsheet palette.
Bimsheet: Export
Use this tool for automating the extraction of information from your models into Excel. The workflow inside this tool is the following:
  1. Opens a Bimsheet file (Excel)
  2. Fills the Bimsheet with data from your model
  3. Exports a plain Excel file with your data
The parameters for this tool are the Bimsheet file (Excel) and the Excel file you wish to export.
Bimsheet: Enrich
Use this tool for adding information from Excel into your model. The workflow inside this tool is the following:
  1. Opens a Bimsheet Enrichment file (Excel)
  2. Writes the information from the Bimsheet enrichment file into your model
The parameter for this tool is the Bimsheet Enrichment file (Excel).
