Helmert Transformation
Transforms the building element placements using four paramater (x,y,z and rotation) Helmert Transformation. Note Simplebim’s Helmert Transformation never scales the model.
Target
KeyTypeValueDescription
TARGETText<Object Group Name>The object group that should be transformed.
Leave empty to move whole model.
Original Points
ORIGINAL_POINT13D PointThe first pointFor example: ORIGINAL_POINT1=10.0;0.0;20.0;mm
ORIGINAL_POINT23D PointThe second pointFor example: ORIGINAL_POINT2=10.0;0.0;20.0;mm
New Points
NEW_POINT13D PointThe third pointFor example: NEW_POINT1=10.0;0.0;20.0;mm
NEW_POINT23D PointThe fourth pointFor example: NEW_POINT2=10.0;0.0;20.0;mm
Containment
MOVE_CHILDRENOn/OffDefault = ONMove objects with their containers. Otherwise transforming containers is a ‘hidden’ operation that only affects the internal structure of your model, not the placement of any objects.
The following alternative keys and values are supported for backward compatibility.
SOURCE for TARGET
