Simplebim Command Line API
The Simplebim® command line API can be used for importing IFC, applying a template and exporting IFC. The number and order of the command line parameters is significant. If folder or file names contain spaces the name must be enclosed in quotes.
Importing IFC
Starts Simplebim® and imports the specified file into the Editor model view using the full IFC import.
Syntax
Simplebim10.exe ImportFile
Simplebim9.exe ImportFile
Simplebim8.exe ImportFile
Simplebim7.exe ImportFile
Simplebim6.exe ImportFile
Simplebim5.exe ImportFile
Parameters
ImportFile | The IFC file (with full path) to import. |
Example
Simplebim10.exe “C:\My Files\In.ifc”
Importing IFC with template
Starts Simplebim®, imports the specified file into the Editor model view using the full IFC import and applies the specified template.
Syntax
Simplebim10.exe ImportFile TemplateFile
Simplebim9.exe ImportFile TemplateFile
Simplebim8.exe ImportFile TemplateFile
Simplebim7.exe ImportFile TemplateFile
Simplebim6.exe ImportFile TemplateFile
Simplebim5.exe ImportFile TemplateFile
Parameters
TemplateFile | The Simplebim® template to apply. |
Example
Simplebim10.exe “C:\My Files\In.ifc” “C:\My Files\Template.xls”
Exporting IFC
Starts Simplebim®, imports the specified file into the Editor model view using the full IFC import, applies the specified template and exports the result to the specified IFC file.
Syntax
Simplebim10.exe ImportFile TemplateFile ExportFile
Simplebim9.exe ImportFile TemplateFile ExportFile
Simplebim8.exe ImportFile TemplateFile ExportFile
Simplebim7.exe ImportFile TemplateFile ExportFile
Simplebim6.exe ImportFile TemplateFile ExportFile
Simplebim5.exe ImportFile TemplateFile ExportFile
Parameters
TemplateFile | The Simplebim® template (with full path) to apply to the imported IFC model |
ExportFile | The file (with full path) of the exported IFC file. |
Example
Simplebim10.exe “C:\My Files\In.ifc” “C:\My Files\Template.xls” “C:\My Files\Out.ifc”
Exporting IFC silent
Starts Simplebim®, imports the specified file into the Editor model view using the full IFC import, applies the specified template, exports the result to the specified IFC file and closes Simplebim. During the operation Simplebim® runs minimized.
Syntax
Simplebim10.exe ImportFile TemplateFile ExportFile Close
Simplebim9.exe ImportFile TemplateFile ExportFile Close
Simplebim8.exe ImportFile TemplateFile ExportFile Close
Simplebim7.exe ImportFile TemplateFile ExportFile Close
Simplebim6.exe ImportFile TemplateFile ExportFile Close
Simplebim5.exe ImportFile TemplateFile ExportFile Close
Parameters
Close | Including the keyword Close as the last parameter instructs Simplebim to run minimized and close itself once the operation is completed. |
Example
Simplebim10.exe “C:\My Files\In.ifc” “C:\My Files\Template.xls” “C:\My Files\Out.ifc” Close
Batch processing with a script file
Processing of models can be further automated with a script file that is passed to Simplebim as a parameter
If your script contains non-ANSI characters, such as ä, å or ü, your script file must be saved using UTF8 encoding. The UTF8 encoding can be with or without BOM (Byte Order Mark).
If you run your script from a batch file (.bat) and any of your folder or file names contain non-ANSI characters, such as ä, å or ü, you need to define the correct code page as the first row of your batch file using the CHCP command. For example…
CHCP 1252
…will set the code page to the Latin alphabet used e.g. for English, Irish, Italian, Norwegian, Portuguese, Spanish, Swedish, German, Finnish and French.
Syntax
Simplebim10.exe ScriptFile ModelFile
Simplebim9.exe ScriptFile ModelFile
Simplebim8.exe ScriptFile ModelFile
Simplebim7.exe ScriptFile
Simplebim6.exe ScriptFile
Simplebim5.exe ScriptFile
The file extension of the script file is .sbs (Simplebim script). The file is a simple ASCII file with one command on each line. The commands are processed in the order they appear in the file. In order to run silently the script file must end with a Close command. The # character at the start of a line denotes a comment.
Simplebim 8.0 SR6 and later. In addition to the script file you can optionally also pass a model file to Simplebim. The model file is parsed into the following variables that you can use in your script just like any other variables. The documentation below shows the values for each variable when ModelFile is: C:\MyFiles\Scripts\Sample.ifc
MODEL_FILE | The ModelFile parameter you passed to Simplebim | C:\MyFiles\Scripts\Sample.ifc |
MODEL_PATH | The folder of the model file without the trailing backslash | C:\MyFiles\Scripts |
MODEL_NAME | The name of the model file without the path and without the file extension | Sample |
MODEL_EXT | The file extension of the model file without the preceding dot | ifc |
With this feature you can for example create an entry for your script in the Windows Send To -list. First you create a shortcut to the Simplebim EXE file and add your script as a parameter to the shortcut. Then you register your shortcut in the Send To -list. When you now right click on any IFC file and select your script from Send To list, Simplebim will start and process your script. When you use the variables above in your script you can for example automate applying a template to the selected IFC file and export the result to another IFC file. Your script could look for example like this:
Import=%MODEL_FILE%
Apply=%SCRIPT_PATH%\MyTemplate.xlsm
Export=%MODEL_PATH%\%MODEL_NAME% (EDITED).%MODEL_EXT%
Close
Commands
Variable=
You can define any number of variables that consist of a variable name and value. When the script is parsed and the variable name in the format %NAME% is found anywhere in the script, it is replaced with the value you have defined. Variable names are case sensitive. Using variables makes it easier to adapt your script to new situations for example a new project.Variable=NAME=valueThe variable %SCRIPT_PATH% is always defined automatically and has the full path of the script file you are running as the value.
Setting=
You can set the following pre-defined settingsTempFolder=<folder>Redirect temporary files into another folder than the default temporary folder. This can be useful with large models if the size of the default temporary folder is limited.Example: Setting=TempFolder=C:\Temp
Import=
Open=
The Cube file (with full path) to open
Apply=
The Simplebim template (with full path) to apply to the imported IFC modelNOTE: You may apply several templates in sequence to the same modelYou can define variables that are passed to the template you apply using the same syntax as when you run tools. In the template, use the syntax %NAME% anywhere and the name of the parameter is replaced with the value of the parameter. This reduces the number of template files you have to create because you can make a generic template that you configure with parameters.
Run=
The GUID or name of the tool that should be run. The tool can optionally be configured using the following syntax
Run=ToolNameOrGuid|key1|key2=value2|key3=value
Merge=
The IFC file (with full path) to merge to the already imported or opened model. Merge can optionally be configured using the following syntax
Merge=File|key1|key2=value2|key3=value3
You can use wildcards in the File parameter. For example C:\Script Files\*.ifc When the script is parsed the directory specified in the File parameter is scanned for files that match the pattern and a separate command is automatically created for each file. This makes it easier to re-use script files with different combinations of file that need to be merged.
The supported configurations are:
Key | Value(s) | Description |
MERGE_TYPE | FULL (default) CREATELOCATIONPRISMS READLOCATIONPRISMS | Merge the full model, create 3D location prisms from footprints or read only 3D location prisms from the model. |
MERGE_SITES | n/a | Merge sites |
MERGE_SITES_BY_NAME | ON OFF (default) | Merge sites by their name The resulting model has only one site |
MERGE_BUILDINGS | n/a | Merge buildings |
MERGE_BUILDINGS_BY_NAME | ON OFF (Default) | Merge buildings within each site by the building name. The resulting model has only one building on each site. |
MERGE_BUILDING_STOREYS_BY_NAME | n/a | Merge building storeys by name. Can only be used with MERGE_BUILDINGS. Can be used together with MERGE_BUILDING_STOREYS_BY_ELEVATION |
MERGE_BUILDING_STOREYS_BY_ELEVATION | n/a | Merge building storeys by elevation. Can only be used with MERGE_BUILDINGS. Can be used together with MERGE_BUILDING_STOREYS_BY_NAME |
BY_BUILDINGSTOREYS | ON OFF (default) | Only relevant with CREATELOCATIONPRISMS. Create a separate location prism for each building storey. |
EXTEND_LOWEST_BUILDINGSTOREY | ON (default) OFF | Only relevant with CREATELOCATIONPRISMS. Extends the bottommost location prism down to the bottom elevation of the lowest building element. |
Export=
Save=
The file (with full path) of the saved Cube file
Delete=
The file (with full path) of the file to delete. The user will not be prompted to confirm the delete operation.
StartLog=
The file (with full path) of the log fileStartLog may appear anywhere after the first Import and the final Close. You can write a separate log for each operation, one log for the whole script or for any sequence of operations in between.
SaveLog
Saves the log into the log file specified in StartLog
Close=
The file (with full path) of the log file for the event of an application crash. If the application does not crash the log file is not written. Close can also be used without a value
Example Script
# This is a comment
Variable=PATH=C:\My Files
Import=%PATH%\test1.ifc
Merge=%PATH%\location_prisms.ifc|MERGE_TYPE=READLOCATIONPRISMS
Run=Split Geometries|SPLIT_TYPE=ALL|SMART_SPLIT=OFF
Save=%PATH%\test1.cube
StartLog=%PATH%\test1_out1.log
Apply=%PATH%\test1.xlsx
Run=Basic Quantities
SaveLog Export=%PATH%\test1_out1.ifc
Open=%PATH%\test1.cube
StartLog=%PATH%\test1_out2.log
Apply=%PATH%\test2.xlsx
Apply=%PATH%\test3.xlsx
SaveLog
Export=%PATH%\test1_out2.ifc
Delete=%PATH%\test1.cube
Close=%PATH%\test1_fail.log/p>
The example script above does the following.
- Comment line that does nothing
- Defines the variable PATH with the value C:\MyFiles
- Imports a model from a IFC file (test1.ifc)
- Merges location prisms from another IFC file (location_prisms.ifc)
- Resolves the locations and splits objects if needed by running the Split Geometries tool
- Saves the imported model to a binary file (test1.cube). This is done because it is later faster to open the binary file than to re-import the IFC file
- Starts writing the log for applying a template (test1_out1.log)
- Applies a template (test1.xlsx)
- Saves the log for applying the template (into test1_out1.log)
- Exports the modified model into a new IFC file (test1_out1.ifc)
- Opens the model from the binary file (test1.cube) saved in step 2. This is done in order to get a clean model for applying the next templates.
- Starts writing the log for applying the next templates (test1_out2.log)
- Applies the first template (test2.xlsx)
- Applies the second template (test3.xlsx)
- Saves the log for applying the first and second template (into test1_out2.log)
- Exports the modified model into a new IFC file (test1_out2.ifc)
- Deletes the binary file (test1.cube)
- Closes the application. If the application crashes during any of the steps above the reason for the crash will be written into the specified file (test1_fail.log)
