Trim Properties in Template
Include/Exclude Property -section
In this section you can include and exclude properties from Object Classes.
If you want to start with a clean slate, use the special value ‘All’ for both Object and Property on the first row. This will exclude all properties for all objects. Then you can start including the properties you really need.
Object [+] | Text | The name of identity key of the Object Class. | The special value ‘All’ will apply the operation to all Object Classes. |
Property [+] | Text | The name of identity key of the property. | The special value ‘All’ will apply the operation to all properties of the applicable Object Classes. The special value ‘Added’ will apply the operation to all properties that were added to the applicable Object Classes by any template in the current template stack. NOTE: You can use the prefix [PSET] or [QSET] to include/exclude all properties from a property set or quantity set, for example ‘[PSET]My Properties’ would include/exclude all properties from a property set called ‘My Properties’. NOTE: You can use the prefix [LIKE] to enable wildcards. For example ‘[LIKE]*abc*’ would include/exclude all properties where the name contains ‘abc’. |
Include | Yes/No | Yes/No | Include the property? |
