Trim Text Property Values
You can use this section to trim away part of a text property value, for example a prefix or postfix. You could for example trim a ‘Basic Wall’ prefix from the building element construction type of walls.
There is a separate section in the template for trimming before copy operations and after copy operations because the order of events determines if the trim is applied to a copied value or to the original value.
FieldTypeValueDescription
Object or Group [+]TextName or identity keyThe name or identity key of the Object Class or Group
Trim PropertyTextName or identity keyThe name or identity key of the text property to trim
Trim TypeChoiceThe type of the trimming. Allowed values are: prefix, postfix, anywhere, regex and regex inverse.
Case SensitiveYes/NoYes/NoPerform case sensitive comparison? This setting is ignored if the trim type is regex or regex inverse.
Text to TrimTextThe text to trim from the position defined by the trim type.If the trim type is regex or regex inverse, the value in this cell is used as the regular expression.
