Add Identity to Object
In this section you can add new identities (names) for Object Classes. This has no effect on the IFC export but allows you for example to translate the names of object classes to your own language in the Simplebim user interface.
Object [+] | Text | Name or identity key | The name or identity key of the Object Class |
Identity to Add [+] | Text | Name or identity key | The name or identity key of the identity to add |
Make Default | Yes/No | Yes/No | Make this the default identity, i.e. the name that is shown in the Simplebim user interface? |
