Add Identity to Property
In this section you can add new identities (names) for properties. This has no effect on the IFC export but allows you for example to translate the names of properties to your own language in the Simplebim user interface.
FieldTypeValueDescription
Object [+]TextName or identity keyThe name or identity key of the Object Class
Existing PropertyTextName or identity keyThe name or identity key of the property you want to add the new identity to. This property must already exist on the object class.
Identity to Add [+]TextName or identity keyThe name or identity key of the identity to add
Make DefaultYes/NoYes/NoMake this the default identity, i.e. the name that is shown in the Simplebim user interface?
