Selecting User Interface Language
Simplebim supports multiple languages for the user interface and the language can be set from the user interface or using a configuration file.
Selecting language from the user interface
From the File -menu select ‘Select Language’ and then the desired language.
The language you choose will be used once you restart Simplebim.
Selecting language with a configuration file
The user interface language can be set by placing an XML file with the following content and the file extension .config into a sub folder of the Configuration sub folder of the Simplebim installation folder. For example
C:\Program Files\Datacubist\Simplebim 10\Configuration\Language\DefaultLanguage.config
Please note that you have to create the Configuration sub folder if it is missing.
<?xml version="1.0" encoding="utf-8"?>
<Settings xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.datacubist.com/simplebim.developer/settings/1.0">
<Values>
<StringValue Name="MergeType" Value="Installed" />
</Values>
<Nodes>
<Node Key="Locale">
<Values>
<StringValue Name="DefaultLocale" Value="de-DE" />
<BooleanValue Name="ForceDefaultLocale" Value="false" />
</Values>
</Node>
</Nodes>
</Settings>
The DefaultLocale
value defines the locale to be used when Simplebim is started for the first time on a computer. The currently supported locale codes are:
en-EN | English (default) |
de-DE | German |
es-ES | Spanish |
fi-FI | Finnish |
fr-FR | French |
By default the user can choose another language even if a default is set. However, if you set the value of ForceDefaultLocale
to true
, then the language selection will not be visible in the user interface and the user must use the language you have set as the default.
