Firewall Settings
For activating the license Simplebim must have access to the internet. As a minimum you configure your firewall to allow traffic between Simplebim and the following addresses.
On Sept-18 2023 we moved our simplebim.com site to a new server. Because of this the DNS entry of simplebim.com changed. If Simplebim used to work but now your firewall no longer lets traffic through to simplebim.com, please remove the old entry in your firewall and add a new (identical) entry per the instructions below.
Trial Activation
Protocol | Host | URL |
HTTPS | simplebim.com | /api |
License Activation
HTTPS | quicklicensemanager.com | /datacubist/qlm/qlmservice.asmx |
HTTPS Protocols
simplebim com | TLS_AES_128_GCM_SHA256, 128 bit keys, TLS 1.3 |
quicklicensemanager.com | TLS_AES_128_GCM_SHA384, 256 bit keys, TLS 1.3 |
Using Offline
If you can’t allow Simplebim to access the Internet you can also activate Simplebim offline with certain limitations.
