Group Merge
Tool for merging several groups with a similar name into a new group. Creates a new group with a given name, copies all objects from all groups where the name matches a given pattern and finally deletes the original groups from which the objects were copied.
The new group is of the same type as the groups from which the objects were copied. For example when objects are copied from Zone -groups the new group will also be a Zone. If there is a mismatch in the group type, for example you try merge Zones and Systems the operation will fail and no new group is created and no existing groups are deleted.
Because type objects, like wall types, are internally groups in Simplebim this tool can also be used for merging type objects.
Configuration Options
Because this tool needs to be configured it can only beĀ run from a template. This tool is not visible in the Tools drop-down menu of the ribbon.
Key | Type | Value | Description |
TARGET | Choice | Defines the target of the operation, i.e. the groups that might be deleted by the tool. For example TARGET=ZONE specifies that only groups mapped to IfcZone may be deleted. | |
ALL | Default. All groups. | ||
GROUP | Groups mapped to IfcGroup. | ||
ASSET | Groups mapped to IfcAsset. | ||
INVENTORY | Groups mapped to IfcInventory. | ||
SYSTEM | Groups mapped to IfcSystem. | ||
BUILDINGSYSTEM | Groups mapped to IfcBuildingSystem. | ||
DISTRIBUTIONSYSTEM | Groups mapped to IfcDistributionSystem. | ||
DISTRIBUTIONCIRCUIT | Groups mapped to IfcDistributionCircuit. | ||
ZONE | Groups mapped to IfcZone. | ||
<Object Class> | This option is used for merging type objects. For example the value WALL sets the target to types of IfcWall. NOTE: It is possible to merge also type objects with this tool because internally type objects are handled as groups in Simplebim. | ||
NAME | Text | Any text | The name of the new group |
PATTERN | Text | The pattern the name of the target group must match to be merged | The value may contain the wild cards * and ?. Examples – ‘ABC*’ merges all groups where the name starts with ‘ABC’ – ‘*ABC’ merges all groups where the name ends with ‘ABC’ – ‘A*C’ merges all groups where the name starts with A followed by any number of characters ending with B. – ‘A???C’ merges all groups where the name starts with A followed by any 3 characters and ends with B. |
