Using Custom Temporary Files Folder
NOTE: This feature was added in Simplebim 10.0 SR1
By default Simplebim writes temporary files into the following folder in the user’s profile.
C:\Users\<user name>\AppData\Local\Temp\Datacubist\SimplebimDeveloper1\Simplebim10
However, there can be scenarios where this is not desirable and it is possible to set a custom folder for the temporary files.
Place an XML file with the following content and the file extension .config into a sub folder of the Configuration sub folder of the Simplebim installation folder. For example:
C:\Program Files\Datacubist\Simplebim 10\Configuration\TempFolder\CustomTemporaryFilesFolder.config
Please note that you have to create the Configuration sub folder if it is missing.
<?xml version="1.0" encoding="utf-8"?>
<Settings xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.datacubist.com/simplebim.developer/settings/1.0">
<Values>
<StringValue Name="MergeType" Value="Installed" />
</Values>
<Nodes>
<Node Key="TemporaryFilesFolder">
<Values>
<StringValue Name="Path" Value="C:\Temp" />
</Values>
</Node>
</Nodes>
</Settings>
