Configure – Calculate Quantities
Calculates basic quantities for objects based on their 3D geometry.
See how to run tools here.
See hwo to configure tools here.
Key | Type | Value |
SHADOW_AREAS | On/Off | Calculate shadow areas for all objects Default = ON |
CONTAINERS | On/Off | Calculate quantities for containers based on the parts of the container Default = ON |
SMALL_OPENING_THRESHOLD | Area | Ignore openings smaller than this value in net area and net volume calculations Default = 0 m2 |
DENSITY_FOR_WEIGHT | Number | The density for weight calculations. The default 7850kg/m3 is the density for steel Default = 7850 |
PSET_NAME | Text | The name of the property set into which all properties created by this tool are written Default = ePset_SimplebimBasicQuantities |
The following alternative keys and values are supported for backward compatibility:
SHADOWAREAS for SHADOW_AREAS
SMALLOPENINGTHRESHOLD for SMALL_OPENING_THRESHOLD
DENSITYFORWEIGHT for DENSITY_FOR_WEIGHT
