Download Simplebim Templates
On this page you find sample templates to get quickly started with Simplebim automation. To learn how to create your own templates click here. To learn more about template explore the template guide here.
Editing Sample | This template demonstrates the IFC model editing capabilities of Simplebim, like setting, copying, trimming and swapping property values. | Download |
Validation Sample | This template demonstrates the IFC model validation capabilities of Simplebim, like how to define objects and properties as required and set lists of allowed property values. | Download |
Enrichment Sample | This template demonstrates the IFC model enrichment capabilities of Simplebim, like how to add new properties to the model and set the values of those properties. | Download |
Add property | Minimal sample template for adding a property to the model. | Download |
Add measure value | This is a template sample for adding a measure value to the model. | Download |
Add property to all objects and containers | This template adds example properties to all elements and containers. | Download |
Add building storeys | This is a sample template for adding building storeys to a model. | Download |
Add Uniformat classification | This is a template for adding the Uniformat classification to the model. | Download |
Add TALO 2000 classification | This is a template for adding the TALO 2000 classification to the model. | Download |
Define the scope of the model | This is a sample template for defining which objects and properties are included/excluded. | Download |
Exclude all properties | This template excludes all properties from all objects, except model information, project, site, building and building storey. | Download |
Find and Replace Sample | This template demonstrates how to use Find and Replace Text Property Values function. | Download |
Show GUIDs | Normally GUIDs (GlobalId) are not shown in Simplebim, but with this template you can make a copy the GUID visible for all objects. Please note that editing this copy does not change the original GUID that remains hidden and that the copy is not exported to IFC. | Download |
Show Door GUIDs | This template makes the IFC GUID (GlobalID) of door objects visible in the Simplebim user interface. | Download |
Copy Type GUID to instance | Copies the GUID (GlobalID) of the type object to the instance. | Download |
Exclude Parent GUID | This template excludes the parent GUID property for all objects. | Download |
Exclude Assembly Level | Excludes the Assembly Level property from all objects. | Download |
Add rule based groups | This is a template for generating groups based on property values in the model. | Download |
Add manual Group | This is a template for adding a new manual group to the model. | Download |
Create Space Covering objects | This is a template for creating space covering objects. | Download |
Building Element Proxy Types | Create type objects for building element proxy objects. | Download |
Wall types | Create type objects for walls. | Download |
Copy Model Name to objects | This template copies the model name property to all elements. | Download |
Copy Model Name to Project | This template copies the name of the model to the project. | Download |
Combine Space Name and Space Number | This template uses the ‘Calculate Properties for Objects’ tool to combine values from “Space Name” and “Space Number” properties. | Download |
Color by value example | Example for coloring objects based on property values. | Download |
Colorize by layer | This is a template demonstrates how to colorize objects by their layer. | Download |
Set transparency | Sample template for setting the transparency of objects. | Download |
Move the model | This is a sample template for moving the model. | Download |
Moving the model to global origin | This is a sample template for moving the model to the global origin (x=0, y=0, z=0). | Download |
Rotate model | This template demonstrates how to rotate the model. | Download |
Substitution sample | Sample template for demonstrating the use of substitution lists. | Download |
REGEX sample | This is a template for testing regular expressions. | Download |
Do not split Spaces | Prevents Space objects from splitting by adding boolean property. | Download |
